GAS EVAPORATION MYTHS
»Myth: Warmer gasoline expands, while cooler gasoline is denser. Since gasoline is priced by the gallon, buying gas when ground temperatures are cooler means more BTUs per gallon.
Fact: According to
Consumer Reports, the temperature of gasoline, as it is being pumped from underground tanks into your vehicle, changes very little, if any, during the course of the day. Any more gas you may obtain is negligible.
Myth or Fact? More gasoline is lost through evaporation when refueling in a 90° F state, compared to a state with temperatures in the 70° F range.
Fact: According to David Champion, Senior Director of Auto Testing for Consumer Reports, gas evaporation during refueling is least during the coolest times of the day. However, with modern fuel pumps, any loss is negligible. In the summer, a decrease in fuel-efficiency may be attributed to another source. According to the EPA in certain high-ozone areas, the EPA mandates the use of special reformulated gasoline (RFG) during the summer months. RFG causes a small decrease (1-3%) in a vehicle’s fuel economy compared to conventional gasoline. However, it is also less conducive to evaporation than regular gas.
Myth: Fill your tank when it is half full in order to minimize gas evaporation and loss.
Fact: According to API, technical changes to vehicle fuel systems have virtually eliminated fuel evaporation loss.
Myth or Fact? Park in the shade; heat from the sun will result in fuel evaporation and loss.
Fact: According to API, technical changes to vehicle fuel systems have virtually eliminated fuel evaporation loss. David Champion, Senior Director of Auto Testing for Consumer Reports, told the Alliance to Save Energy that a small amount of gas does evaporate from older vehicles (1974 or older). According to the
EPA, avoid poorly fitted or missing gas caps to decrease evaporation loss.»
