Not sure what you are referring to. Since these cars are a hatchback; they don't have trunk lids. They have cargo areas with lift gates. Are you referring to the interior plastic trim? Maybe a picture would help?My trunk lid just broke off today. The plastic around all the bolts broke. Wondering if anyone else had this problem before and if so, how'd you fix it?
No wiserI'm assuming the OP is talking about the plastic piece that has the handle & badges on it.
Best bet woud be to go to a junk yard and find one in the same colour. They aren't that hard to remove & replace.
That entire piece that I highlighted in blue in my above picture is plastic.I see a RAM head badge there!
He's talking about the plastic handle lock release underneath the RAM.
I don't have the parts list with me so I'll look it up in a day or two if no one else chips in first.
You are correct. The handle is integral to that pieceThat entire piece that I highlighted in blue in my above picture is plastic.
I've seen too many reports of the entire piece breaking off - which is what I figured the OP was asking about.
Went with self-tapping screws......problem solved.
You need to remove the entire inside plastic of the lift, then look for the nuts. You’ll also need to disconnect pull-cables and unplug a few things.
Super easy if you have someone helping you. A fair pain trying to do it oneself.
