As topic describe, my brake lights stays on continuesly, even when car is turned off. I have replaced the TIPM with an upgraded one (for various electrical reasons) and replaced the brake pedal switch. The only way to to get the brake lights to turn off, I have to remove the negative battery cable. I checked the ecu with an obd2 reader and no fault codes could be seen. Also checked grounding points for possible failures, but without success.
I can get the brake lights to turn off by placing negative and positive battery cables together to drain the capacitors and wipe the ecu's memory. But as soon I touch the brake pedal, they light up again.
Any thoughts where the trouble could be?
Best regards. Christer.
