Hi guys. So my blower motor will not work on high. Me not researching the problem deep enough, I thought it was my blower motor resistor and with the help of the forum figured out how to replace it, and I replaced it. This however, did not fix the issue. So I tried to reset the TIPM and that did not fix the problem. Is it possible that it is a bad fuse? The blower motor works on all other settings besides high and the temperature works fine.
Thanks so much.
It sounds as if you have covered all the usual
things that would cause the failure so I would
suggest you may want to remove the control
panel and check for poor connection at that
point or failure of control switch.
I would suggest you download the service manual in the forum
manual section it is very comprehensive with every thing and
includes fault finding.
