I just replaced the TIPM today. I checked the blinkers and only the driver side doesn't work. But what's weird is that the bulb would turn on but there's no blink when I want to go left. It'll just hyper blink. I'm thinking it could just be the blinker switch or the bulb may be damaged.
If by "hyper blink" you mean it blinks really fast when you move the stalk to signal a left turn, then that usually indicates a faulty bulb. If you replace the bulb (or swap the two front bulbs) and it still does it, that can be an indicator of a faulty ground
