1 - 7 of 7 Posts
Hello members,
I'm original owner of an 08 SXT 174,000 km. I have replaced my control arms three times I've done all the front end struts tie rods stabilizer links and I have this weird sound almost sounds like it's near the stereo or the steering column whenever I go over a frost heave it's like a squeak that's very loud. Only faster speeds, over 60 km. Sounds like the car is going to split into two sometimes. Does an engine mount sound like that when loose? Thanks for your input.
Likely you'll need to look underneath, maybe the sub-frame.
Something that just occurred to me...get under the car and see if the heat shield above the exhaust has come loose. It's made of aluminum but held in place by steel bolts so the galvanic reaction between them causes the shield to rot under the bolts and come loose
1 - 7 of 7 Posts
