Thank you. Yes, the system comes with the CANBUS module designed for Dodge Caliber.If you have THE multimedia for Chrysler Canbus vehicles then you should have no issues.
Hi again, and apologizes for the previous request. It's a bit much :- ) I do have something that should be a bit quicker to concider? When removing my radio, should I exspect to find two plugs, one larger that services the power and speakers etc. and one small that services the factory CANBUS system? Cheers again!Hello friend, I now have a multimedia unit and will begin to install soon. If you can, would you have any tips as to wiring? Specifically; the power-harness wire-bundle has wires tagged as key1, key 2, brake,amp cont. Would I be correct to assume that they are there to accomidate other models etc? My Caliber has CANBUS to accommodate the steering wheel controls and sub woofer. I do understand that this is a longshot, but I just wanted to try anyway :- ) Cheers!
