I know there are a thousand threads talking about no start / no crank issues and I think I have read most of them. I have a 07 R/T that is sitting dead. I hate to go to a dealer because I fear the digging will cost more than the car is worth. So I'm hoping someone can throw out some ideas. On the surface, this feels like a faulty WCM. But there are a couple of symptoms that don't seem to align. Here's what I have...
Problem - This week went to leave and the car would start easily, run for 2 seconds and then stop - no sputter - just a quick startup and stop. After this happened a few times, it decided it didn't even want to try anymore. Key turns forward, everything powers up - but no crank. No Codes. The other issue is that now the locks won't work from the key fob. Playing around with that, I set the security system off and it would not stop by inserting and turning the key forward. The car didn't care. I struggled with that until I read about the trick to reset the SKREEM. That worked like a champ and I was able to continue troubleshooting with the alarm off. (I can now hook the horn back up
Here is what I checked out...
I keep thinking its the WCM - but i'm thrown off by 1) the fact that the car initially started for 2 seconds a few times before going to no-crank. and 2) if the reset process in the service bulletin doesn't temporarily reset the WCM - is it something else?
Any other ideas on what to check? Is it likely the WCM even though it's not a perfect fit on symptoms?
I'm assuming if it's the WCM I could replace but can't reprogram... So that will suck.
Any feedback would be appreciated! Thanks1
- Checked both key fobs and replaced batteries. WCM still doesn't respond.
- Battery holds charge just fine and is pretty new. Have not had tested for Amp output. But also doesn't help to jump.
- Inspected the relays for corrosion - no obvious issues. Tried swapping a few to eliminate possibility of bad relay.
- Inspected the wires between the relay and fuse box. One wire with insulation worn off but not broken - repaired.
- Checked all the fuses - no issues that I could find. Power to fuses 27/28 when I turn the key forward.
- Tried disconnecting the battery and setting cables together overnight to discharge.
- Reviewed the TSB 08-007-08 REV. A (MY 07, 08)No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM SKREEM.
