No matter what speed or setting I am not getting any air hot or cold. I have changed the fuse but that didnt help. Any ideas on what the issue could be and/or what I can do to fix the problem?
Can you hear the blower running? If so, you likely have a plugged cabin air filter. Instructions for replacing are here: http://www.caliberforumz.com/showthread.php?t=25069
If it makes no noise, as in dead, then you may need a TIPM/PCM reset. That can be found here: http://www.caliberforumz.com/showthread.php?t=39192
If that doesn't do it; then the next step is to read any codes that may have been thrown. It could be the blower motor, the dash control assembly, or a bad connection is the cause. The codes will point to the cause.
