If I wanted to add blinkie flashies to the headlights and brake lights, would I need diodes to prevent voltage from going back into the computer?
Or is there something already built in to prevent back voltage (like from relays)?
The secondary power to the halogen (incandescent) headlights would be regulated 12-volts max, PWM variable at 15kHz.
LED brake lights (with the 15-watt resistors) would be on/off only at 12-volts regulated, if they can't be Pulse Width Modulated.
