1 - 9 of 9 Posts
my 07 calber didnt come with a ouners maual and i need to know what should be done at 90k i dont know what the histoery is so i just wana do a major tune up any one can help ???:loser1:
Welcome to the Calibration! I'm sure somene will be along shortly with your information.
Welcome! Here u can find the service manual.
welcome and much fun
:wavey:
You can go to the owners section at Dodge.com and download a copy of the owners manual. The link Stillframe gave is for the 2007 service manual.
Welcome to the Crew!!! No history???
The Italian Admin
:wavey: Welcome to the ForumZ Family !
Required Maintenance Intervals
Perform Maintenance Every (Where time and mileage are listed, follow the interval that occurs first.)
Maintenance Items Miles Kilometers or Months
Change the engine oil and engine oil filter. 6,000 10 000 6
Rotate tires. 6,000 10 000 6
If using your vehicle for dusty or off-road conditions, inspect the engine air cleaner filter; replace if necessary. 12,000 20 000 12
Inspect the brake linings; replace if necessary. 12,000 20 000 12
Replace the air conditioning filter. 12,000 20 000 12
Inspect the CV Joints. Perform the first inspection at 12,000 mi (20 000 km) or 12 months. 24,000 40 000 24
Inspect Exhaust System. Perform the first inspection at 12,000 mi (20 000 km) or 12 months. 24,000 40 000 24
Inspect the front suspension, tie rod ends and boot seals; replace if necessary. 24,000 40 000 24
Replace the engine air cleaner filter. 30,000 50 000 30
Replace the spark plugs. 30,000 50 000 30
Change the manual transmission fluid if using your vehicle for any of the following: trailer towing, snow plowing, heavy loading, taxi, police, delivery service (commercial service), off-road, desert operation or more then 50% of your driving is at sustained high speeds during hot weather, above 90°F (32°C). 48,000 80 000 48
Change Rear Drive Assembly (RDA) fluid. 60,000 100 000 60
Change Power Transfer Unit (PTU) fluid. 60,000 100 000 60
Change the automatic transmission fluid and filter if using your vehicle for any of the following: police, taxi, fleet or frequent trailer towing. 60,000 100 000 60
Inspect and replace PCV valve if necessary. 90,000 150 000 90
Flush and replace the engine coolant. 102,000 170 000 60
Change the automatic transmission fluid and filter. 120,000 200 000 120
Replace Accessory Drive Belt(s). 120,000 200 000 120
WARNING!
You can be badly injured working on or around a motor vehicle. Do only that service work for which you have the knowledge and the right equipment. If you have any doubt about your ability to perform a service job, take your vehicle to a competent mechanic.
1 - 9 of 9 Posts
