Hi, I’m new to forums so I apologize for any inconvenience, the problem is with my 2011 Dodge Caliber with 140,000Kms on it, I cleaned the throttle body in order to keep it fuel efficient and replaced the throttle body gasket, 2 months later while driving normally, in all of a sudden, the ETC light started blinking and the Traction Control light turned on & the car went into limp mode, I turned off the car then turned it on again and the problem went away, but since then the problem started to happen every morning, when the car is cold (not fully warmed), idling, braking with the RPM lowering to about 1000 - 1200, and the problem started to happen more frequently in the winter.
I was tentative that it might be because of the Throttle body, because I took all the precautions of cleaning it, so I went to a Workshop to scan it and I got these codes:
PCM (Powertrain Control Module)
• P2173 High Airflow/Vacuum Leak Detected (Slow Accumulation)
ABS (Anti-lock Braking System)
• C121C Torque Request Signal Denied
BCM (Body Control Module - TIPMCGW/FCMCGW)
I searched online for solutions and it seemed that changing the throttle body worked for some people, so I tried that but unfortunately the problem didn’t go away, some people mentioned that it might be because of the PCV Valve or the Intake Manifold Gasket.
Does anyone know what is the solution?
• Note: the mechanics knowledge of cars at the dealership is bad they don’t know absolutely anything about cars in my area,
I live in Saudi Arabia so the parts are rare and expensive so I need to change the next part carefully, I apologize if my English isn’t good since it isn’t my native language.
Thanks.
Thanks.
