Hello all I have a 2009 SXT, I’ve been having problems with the vehicle when you try putting it into or out of park sometimes. You have to push the shifter lock override on the side and then you can shift into/out of park. Sometimes it gets stuck in park and you have to do the same thing to get it into drive. Took apart the shifter column and you can see the mechanism working while the brake is pressed. Also the shifter bushing looks good. The problem is only intermittent so I’m not sure what’s going on. Thanks for any advice!
