1 - 13 of 13 Posts
2007 Dodge Caliber 2.0
We just replaced the trans in my car and have the module that it came with. The trans is still slipping out of drive like before. It does this only when it heats up, which is very quickly. Can someone tell me if it's a problem other than the transmission? It's very urgent. This is our only car and it's been out of commission for 3 months now...馃
Buenas.
Te dejo este enlace Que aunque esta en espa帽ol puede servir de ayuda.
Saludos.
Thank you for the reply but I cannot understand Spanish. Can you tell me? I can copy and look up a translation but the video鈥o.
I'm just going to help with what i might know it might be the fix just somethings to look for or try because I'm also a owner of this car and have done ALL my own repairs. 1.Could be a bad transmission cooler.2 Low coolant or transmission fluid was the fluid check to the right level or to much fluid will also cause it to heat up also I won't rule out that module if it's used with x amount of miles on it.Buy a OBD2 SCANNER plug it in to your car computer to see what codes you getting this will help more so then playing the guessing game of what the problem could be,Once you get the codes from the coder reader(OBD2 Scanner)look it up for the Dodge Caliber and it should point you in the right direction,I stop guessing problems with my car long time ago a OBD2 Scanner will be more helpful to you then anyone guessing.
I would recommand a good OBD2 CODE READER is the ANCEL AD310 on Amazon the price is less now then when i first bought it,I have since upgraded and gave that one to my son the ANCEL AD310 is one of the best one here and it's going to be a BIG help to you when you are having car problems.I now have the ANCEL AS500 which is more advance.
The video will tell you how the CVT operates and why it overheats.
To understand it turn on subtitles and select the language in settings.
Ok thank you. We have a Fixd code reader but we cannot afford to buy one more thing unfortunately. I have a bad back and out of work and he鈥檚 not making much with the weather lately.
The trans is still slipping out of drive like before. It does this only when it heats up, which is very quickly...
This could be a plugged filter in the transmission cooler lines. There are two filters for the CVT in these cars, one in the transmission oil pan, and one in the cooler line circuit. If one or both filters are plugged, then very little fluid will flow through the cooler and it will cause your transmission to overheat.
You can see the filter in the cooler line in this thread:
Discussion Starter · #9 ·
Thank you.
Transmission fluid is responsible for keeping the transmission cool. By using too much of it, you could cause an overheating situation, which sounds a little backward at first. However, when you overfill the transmission, there is going to be some leakage from the buildup.
2007 SXT Dodge Calibre
Hello Michael,
I recently purchased a ANCEL AS500 scanner.
When I go to do a scan it dose not recognize the vehicle, and I must choose the vehicle from a drop down list on the screen. It does not give Dodge as an option so I therefore choose Chrysler. It then does the scan and a code that appears is as "P1607 Road bed roughness signal (B 2) : Range".
And yet on the Dodge Forum someone has put up a comprehensive list of the error codes. 2010 OBD-II Caliber codes - DodgeForum.com and when I check on this list and look up P1607 I find that it means "PCM INTERNAL SHUTDOWN TIMER SLOW RATIONALITY".
Communication Device Telephony Gadget Font Portable communications device
So my question to you, do you know which definition of code I should accept? The one that is on the scanner, or the one that is on the comprehensive list. If I should be going by the comprehensive list, is there anyway that I can get the scanner to show correct defintions of the error codes, so that I do not have to go cross referencing.
Cheers David.
If, instead of choosing "Chrysler," you chose "Jeep," what code comes up then?
If you're not scanning for the correct vehicle, you could be getting the wrong code and all this would be meaninless.
I'd highly suggest getting a code reader that can read Dodge Calibers.
From memory, Jeep is not an option either. All of these veheicles are Chrysler. I brought this model, as fe Dodge Caliber onwers I have read on fourms and Caliber facebook groups, had purchased these. Anyhow when I went to purchase it, the description said it suited Dodge Caliber.
I am bit wary about spending more money on another scan tool, only to find the same thing to happen.
1 - 13 of 13 Posts
