| Dodge Caliber Mechanical Problems and Questions Discuss any Dodge Caliber mechanical problems/questions in this forum. Engine, trans, supension, body, interior moving parts, interior/exterior trim panels, etc. |
Thread Tools |
#41
Quote:
NUMBER: 18-033-06 GROUP: Vehicle Performance DATE: November 2, 2006 THE StarSCAN® FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM THE INTERNET. UPDATE CD 6.05 WAS THE LAST CD TO CONTAIN FLASH FILES FOR StarSCAN. StarSCAN® SOFTWARE LEVEL MUST BE AT RELEASE 7.02 SP1 OR HIGHER FOR THIS BULLETIN. SUBJECT: Flash: MIL Illumination/Generator Lamp Illumination/Oil Pressure Lamp Illumination/Driveability Improvements OVERVIEW: This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) and the Transmission Control Module (TCM) with new software and performing a memory reset to clear the adaptive memory of the PCM. CAUTION: VEHICLES (PM/MK) EQUIPPED WITH A CVT TRANSMISSION MUST HAVE THE TRANSMISSION CONTROL MODULE (TCM) CHECKED FOR THE LATEST SOFTWARE LEVEL WHENEVER THE PCM SOFTWARE IS UPGRADED. IF NEWER TCM SOFTWARE IS AVAILABLE, IT MUST BE INSTALLED. MODELS: 2007 (JS) Sebring 2007 (PM) Caliber 2007 (MK49) Compass NOTE: This bulletin applies to PM/MK models equipped with a 1.8L, 2.0L or 2.4L gasoline engine (Sales Code EBA, ECN or ED3) built before October 24, 2006 (MDH 1024XX). NOTE: This bulletin applies to JS models equipped with a 2.4L (Sales Code ED3) with the condition of momentary (1 to 2 second) oil indicator lamp illumination or flicker at idle and was originally addressed with RRT 06-048 Dated October 17, 2006. 18-033-06 -2 SYMPTOM/CONDITION: Some customers may experience MIL illumination, Intermittent Generator Lamp Illumination, Momentary (1 to 2 second) Oil indicator lamp illumination/flicker at idle or momentary delay returning to idle after clutch actuation. NOTE: Momentary oil lamp illumination at idle is due to oil pressure switch venting. This will NOT cause engine damage. This condition is most noticeable when the oil is hot, engine RPM is returned to idle and engine load from the power steering system is quickly applied. The technician may find one or more of the following DTC's or Symptoms: • P0139 -O2 Sensor 1/2 Slow Response. • P0700 -Transmission Control System (MIL REQUEST). This DTC is logged in PCM and when TCM is checked, DTC's are not present. • P063A -Generator Voltage Sense Circuit (Intermittent Generator Lamp Illumination). • Momentary (1 to 2 second) Oil Indicator Lamp Illumination or Flicker at Idle • Momentary Delay Returning to Idle when clutch is actuated (Vehicles Equipped with 2.4L Engine and Manual Transmission (Sales Code ED3 and DD7). DIAGNOSIS: Using a Scan Tool (StarSCAN®) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all engine systems are functioning as designed. If DTC's are present record them on the repair order and repair as necessary before proceeding further with this bulletin. If any of the above Symptom/Conditions are present, perform the Repair Procedure. If P0139 was present, verify exhaust system integrity after the reprogramming event by performing the drive cycle listed in TechCONNECT>Engine Electrical Diagnosis>Diagnosis and Testing>P0139, follow step 10. If P0139 reoccurs exhaust system leak checks and repairs will be required. Follow procedures listed in TechCONNECT>Engine Electrical Diagnosis>Diagnosis and Testing>Checking the Exhaust System for Leaks. PARTS REQUIRED: Qty. Part No. Description 1 04275086AB Label, Authorized Modification SPECIAL TOOLS / EQUIPMENT REQUIRED: NPN Battery Charger CH9401 StarSCAN® Tool CH9404 StarSCAN® Vehicle Cable CH9409 StarSCAN® Documentation Kit CH9410 StarSCAN® Ethernet Cable, 12 ft. CH9412 StarSCAN® Software Update Device Kit TechCONNECT PC or equivalent -3- 18-033-06 REPAIR PROCEDURE -USING THE INTERNET TO RETRIEVE THE FLASH FILE: CAUTION: DO NOT START THE ENGINE PRIOR TO COMPLETING **STEP 5n and/or 8h**. IF THE PROCEDURE IS NOT ADHERED TO THE CONTROLLERS MAY NOT COMPLETE THE PROGRAMMING PROCESS. NOTE: When performing this Repair Procedure, the software release level in the StarSCAN®; must be programmed with 7.02 SP1 software or higher. The software release level is visible in the blue header at the top of the StarSCAN® screen. NOTE: The StarSCAN® diagnostic scan tool fully supports Internet connectivity. However, to take advantage of this feature you must first configure the StarSCAN® for your dealership's network. Make sure the StarSCAN® is configured to the dealership's network before proceeding. For instruction on setting up your StarSCAN® for the dealer's network refer to either: “DealerCONNECT > Service > StarSCAN and StarMOBILE tools > Online Documentation”, or refer to the StarSCAN® Quick Start Networking Guide. The StarSCAN® Quick Start Networking Guide is also available on the www.dcctools.com website under the "Download Center". NOTE: If this flash process is interrupted/aborted, the flash should be restarted. 1. Install a battery charger and verify that the charging rate provides approximately 13.5 volts. Set the battery charger to continuous charge. Do not allow the charger to time out during the flash process. Remove the charger from the battery when the flash process is complete. 2. Connect the CH9410 StarSCAN® ethernet cable to the StarSCAN® and the dealer's network drop. 3. Connect the CH9404 StarSCAN® vehicle cable to the StarSCAN® and the vehicle. 4. Power ON the StarSCAN®. 5. Using the StarSCAN® at the “Home” screen: a. Select “ECU View” b. Touch the screen to highlight the PCM in the list of modules. c. Select “More Options” d. Select “ECU Flash” e. Record the part number at the top of the “Flash PCM” screen for later reference. f. Select “Browse for New File”. Follow the on screen instructions. g. Select “Download to Scantool”. h. Select “Close” after the download is complete, then select “Back”. i. Highlight the listed calibration. j. Select “Update Controller”. Follow on screen instructions. k. When the update is complete, select “OK”. l. Verify the part number at the top of the “Flash PCM” screen has updated to the new part number. m.Turn the ignition switch to the OFF position for no less than 15 seconds. n. Turn the ignition switch to the RUN position (DO NOT CRANK THE ENGINE) for no less than 20 seconds. 18-033-06 -4- CAUTION: DO NOT START THE ENGINE PRIOR TO COMPLETING 5n OR 8h. IF THE PROCEDURE IS NOT ADHERED TO THE CONTROLLER MAY NOT COMPLETE THE PROGRAMMING PROCESS. NOTE: Due to the PCM programming procedure, a DTC may be set in other modules within the vehicle. Some DTC's may cause the MIL to illuminate. From the “Home” screen select “System View”. Then select “All DTCs”. Press “Clear All Stored DTCs” if there are any DTCs shown on the list. PM/MK Models equipped with a CVT must have the TCM reprogrammed as follows: 6. Using the StarSCAN® at the “Home” screen: a. Select “ECU View” b. Touch the screen to highlight the TCM in the list of modules. c. Select “More Options” d. Select “ECU Flash” e. Record the part number at the top of the “Flash TCM” screen for later reference. f. Select “Browse for New File”. Follow the on screen instructions. 7. Is the TCM part number recorded in step 6e above, the same as the new p/n shown on the “Flash File List” screen? a. Yes >> No further action is necessary. Proceed to Step #9. b. No >> the TCM will require flash reprogramming also, proceed to Step #8. 8. Flash reprogram the TCM as follows: a. From the “Flash File List” screen, select “Download to Scantool”. b. Select “Close” after the download is complete, then select “Back”. c. Highlight the listed calibration. d. Select “Update Controller”. Follow on screen instructions. e. When the update is complete, select “OK”. f. Verify the part number at the top of the “Flash TCM” screen has updated to the new part number. g. Turn the ignition switch to the OFF position for no less than 15 seconds. h. Turn the ignition switch to the RUN position (DO NOT CRANK THE ENGINE) for no less than 20 seconds. CAUTION: DO NOT START THE ENGINE PRIOR TO COMPLETING STEP 5n and 8h. IF THE PROCEDURE IS NOT ADHERED TO THE CONTROLLER MAY NOT COMPLETE THE PROGRAMMING PROCESS. NOTE: Due to the TCM programming procedure, a DTC may be set in other modules within the vehicle. Some DTC's may cause the MIL to illuminate. From the “Home” screen select “System View”. Then select “All DTCs”. Press “Clear All Stored DTCs” if there are any DTCs shown on the list.** 9. Reset the adaptive memory of the PCM with the StarSCAN®. Using the StarSCAN® at the “Home Screen”: a. Select “ECU View”. b. Highlight “PCM” in the list of modules; c. Select “Misc. Functions”. d. Select “Reset Memory”. e. Select “All Adaptive Memory”. -5-18-033-06 NOTE: The following step is required by law when reprogramming a PCM and/or TCM. 10. Type the necessary information on the “Authorized Modification Label” p/n 04275086AB and attach near the VECI label (Fig. 1). Fig. 1 AUTHORIZED MODIFICATION LABEL 1 -**POWERTRAIN CONTROL / TRANSMISSION CONTROL MODULE P/N's (INSERT P/N's) USED** 2 -CHANGE AUTHORITY: TSB XX-XXX-XX 3 -DEALER CODE: XXXXX 4 -DATE: XX-XX-XX POLICY: Reimbursable within the provisions of the warranty. TIME ALLOWANCE: Labor Operation No: Description Amount 18-19-06-29 (JS) Module, Powertrain Control (PCM) Reprogram (B) 0.4 Hrs. 18-19-03-14 (PM/MK w/MT) Module, Powertrain Control (PCM) -Reprogram (B) 0.4 Hrs. 18-19-03-15 (PM/MK w/CVT) Module, Powertrain Control (PCM) and Transmission Control (TCM) Reprogram (B) 0.5 Hrs. Last edited by Quiet Lunatic; 02-10-2007 at 05:09 PM. |
| Sponsored links |
#42
Well my husband is still at the dealership....over 3 hours now...trying to get some answers ...he has been waiting for the owner ...who he is told is on his way....over an hour wait....hummm...maybe a stall of another kind....we've had this car for 17 days ....three days of it in the shop.....thanks for the answers they have given more info to lay on them at the dealership.
#43
Quote:
__________________
Brad
#44
Well here's the update, our Caliber SE still in shop...they have taken "pictures" of the problem and sent them off to Chrysler head office...they have no idea what the problem is...it stalled while under power...& towed to dealership within 24 hour of the sale, that was Jan 23/07 .. now it stalls again......it sputtered while the mechanic was telling us it's due to driver error, then it stalled in traffic (10 minutes later) brought it back on Friday last and it sits there still...they are waiting for the "engineering department" from Chrysler to diagnos the problem...that was three days ago......they now have all our money (paid cash) our new car and our trade in....if this was a toaster I'd have taken it back and bought another-one elsewhere.....what to do
#45
We have showed this to them and they asked where we got it and that they nothing about this problem and nothing about any recalls on the Caliber. We are getting shafted, we are fighting...as hard as you can imagine.
#46
It has surprised me how reluctant Dodge is to communicate to owners and dealers. The dealership went through the same process with me - I took the sheet in from this forum and finally they realized there was a flash update out there. Calling Dodge directly I was told to talk to the dealership - the dealership said Dodge had no answers - as a customer I was left hanging. They finally did get it fixed and the car works well but I was left with a feeling that in Dodge's opinion I was lucky they let me buy one of their vehicles and I should be thankful.
#47
I bought my car in Sept. of last year. I have probably driven the car 4 1/2 out of 6 months. It stalls when the engine is cold. We have had it into the dealership 5 times now for the same problem and been told "it's fixed" and "weather through it". They have basically treated me as if I am making it up.
I do understand that I bought a first model year car, but most people would think with the help of the GOOD Dealership it should still be a good experience even if there is some bugs. I have contacted a Lemon Law Lawyer. I also called Daimler Chrysler's Cust. Service and let them know that we are bordering the parameters of the Lemon Law. They told my husband that we have to get a second opinion from another dodge dealership, so as dumb as I think that is, that is our next step if I get my car back anytime soon. They have given me a loaner, but I'm sick of messing with it. I'm regreting making the decision on buying a new car. I should have just kept my 95 Camry, it was still runnin like a champ. It's so frustrating.
__________________
Chrysler 300C Accessories | Dodge Avenger Accessories | Dodge Caliber Accessories | Dodge Challenger Accessories | Dodge Charger Accessories | Dodge Nitro Accessories | Dodge Ram Accessories | Chevy Camaro Accessories | Jeep Accessories | Pontiac G8 Accessories | Ford Raptor Accessories | Toyota FT 86 Accessories Chevy Camaro Forum | Chevy Volt Forum|Chrysler 300C Forum | Dodge Avenger Forum | Dodge Challenger Forum | Dodge Caliber Forum | Dodge Circuit Forum | Dodge Charger Forum | Dodge Hornet Forum | Dodge Ram Forum | Ford Raptor Forum | Jeep Forum | Pontiac G6 Forum | Pontiac G8 Forum | Toyota FT 86 Forum | Mopar Nation
#48
Quote:
__________________
Brad
#49
lol.....someone else is going to get screwed. Hi yea, is it an under power problem when the accelerator is slightly pressed and the rpms dive to near stall? Does it stall with the clutch in? If it does you have the problem I had, and now my SE 5speed with 11000kms is in the shop having the transmission replaced. Good luck with dodge paying for ur rental unless you have a service contract. Tell them to reference File Number #15974604 for information about this problem.
Have Fun and Good Luck |
#50
No, it's an automatic. It stalls when the engine is cold, like sitting all night or 8 hours while I'm at work. The only time I have experienced the problem is going to work in the morning and leaving in the afternoon. In colder months I didn't notice it as much since I was letting the engine warm up for 10 minutes or so before leaving.
I have no arguments about the relevence of getting a second opinion, I was referring to the fact that Daimler Chrys. says we HAVE to get it checked out by another dealership before we can say we've got a lemon, but the Illinois State Lemon Law doesn't say anything about taking it to more then one Dealership. DC is above the law apparently.
__________________
| Sponsored links |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ETC (electronic throttle control) Problem | poloplayer14 | Dodge Caliber Mechanical Problems and Questions | 14 | 07-26-2010 02:15 PM |
| SXT newbie | 4evrnyt | Newbie Checkin! | 3 | 10-22-2006 10:13 PM |
| My New Inferno Red Caliber SXT | programmer | Dodge Caliber Photos | 4 | 09-28-2006 10:01 PM |
| my yellow SXT | Quiet Lunatic | Dodge Caliber Photos | 1 | 07-30-2006 07:57 PM |
| Ordered New Caliber SXT 6-26-06 | programmer | Newbie Checkin! | 1 | 07-16-2006 05:10 PM |
