Dodge Ram Dodge Charger Dodge Challenger Dodge Magnum
Mopar Club
Dodge Ram Forum Dodge Charger Forum Dodge Challenger Forum Dodge Magnum Forum
Dodge Dakota Dodge Nitro Jeep Chrysler 300
Dodge Avenger
Dodge Dakota Forum Dodge Nitro Forum Jeep Forum Chrysler 300 Forum
Results 1 to 10 of 10
Thread: CAN Bus Speed?
  1. #1
    Join Date
    Mar 2009
    Location
    Framingham, MA
    Posts
    146
    Rep Power
    6
    Default CAN Bus Speed?
    What exactly is CAN Bus Speed?
  2. #2
    Join Date
    Jun 2006
    Location
    Planet Earth
    Posts
    15,000
    Rep Power
    41
    Default
    It's the baud rate of communication transmission. There are 3 Classes used in the car, A, B, and C. The baud rates range from 10Kbps to 1Mbps. Your internet connection speed is a baud rate.
    Brad
    After 9+ years, 99% of all possible questions have been 100% answered. They're here, it just takes some coaxing.
    Retired this day December 31,2014!
  3. #3
    Join Date
    Mar 2009
    Location
    Framingham, MA
    Posts
    146
    Rep Power
    6
    Default
    thank you very much Brad
  4. #4
    Join Date
    Sep 2008
    Location
    London
    Posts
    11,684
    Rep Power
    26
    Default
    What are the rates used for the Cali MY07 and the upgraded MY09?
    replaced - hub bolts, warped rotors, 3 batteries, 2 screens, 12 alloy wheels, seat cover, armrest, Track-rod ends, clutch master cylinder, LH tail unit, LCAs, rear toe link,
  5. #5
    Join Date
    Jun 2006
    Location
    Planet Earth
    Posts
    15,000
    Rep Power
    41
    Default
    Quote Originally Posted by Aleks View Post
    What I stated above. There has been no change between the years.
    Brad
  6. #6
    Join Date
    Sep 2008
    Location
    London
    Posts
    11,684
    Rep Power
    26
    Default
    Quote Originally Posted by Prop1 View Post
    I was thinking of the thread below imagining it was a USB 1.0 to USB 2.0 type change. So are there three speeds operating on our Canbus and just the Stereo connection got upgraded?
    Quote Originally Posted by rmurad38 View Post
    the Caliber, as with many other DCX vehicles switched from the low to High speed CAN Bus system. The REC is a Low speed device. My 07 (slow speed bus) took the REC without issue, simple plug and play.
    It get confusing with the High Speed Bus vehicles. I do not know if they are backwards compatible with low speed devices. the RER is the "new hotness" so to speak. To add one more layer of complexity, it came/comes in 2 varieties.. a low and high CAN Bus speed version.. I believe either work in the High Speed Vehicles (not sure on the '08) but only the slow one works w/ an 07.
    rmurad38
  7. #7
    Join Date
    Jun 2006
    Location
    Planet Earth
    Posts
    15,000
    Rep Power
    41
    Default
    CanBus has become a catch-all phrase. LinBus is for the lowest data-rate functions, CanBus for medium speed, MostBus for the high-speed data rates, and FlexRayBus is for safety-critical applications such as steer- and brake-by-wire. Each of these operate in one of the three Classes (A, B, C).
    What Class the sensors and controls operate at is only an assumption based on my years in and around electronics, but I would assume Class B. The radio and lights would probably be Class A, The slowest. I was working on and designed similar circuits for military planes back in the late 80s. That's how old this technology is. But I was on the leading age of technology, then.
    Brad
  8. #8
    Join Date
    Sep 2008
    Location
    London
    Posts
    11,684
    Rep Power
    26
    Default
    Yeah "Fly-by-Wire" at least it's transferable technology.
    So would you say it was still true that the later head units can not be used in the earlier Calibers due to the Bus speed data rates?
  9. #9
    Join Date
    Jun 2006
    Location
    Planet Earth
    Posts
    15,000
    Rep Power
    41
    Default
    I seriously doubt that the bus speed is any different for the radios.
    Brad
  10. #10
    Join Date
    Sep 2008
    Location
    London
    Posts
    11,684
    Rep Power
    26
    Default
    Standardizing In-vehicle LAN Interfaces Covering Multiple Functional Areas
    Article gives info on background to Auto Data Standards.
    ForumZ thread about the later head units and earlier Calibers
Similar Threads
  1. BUSTED!!...141 Over the Speed Limit
    By ShockJock in forum Other Vehicle Discussion
    Last Post: 02-11-2009, 03:08 PM
  2. Missing Speed Control
    By goatboy1970 in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 11-07-2008, 11:07 AM
  3. 1.8 L 5 speed manual info/ mpg page
    By Cam in forum Dodge Caliber General Discussion
    Last Post: 06-22-2008, 07:52 PM
  4. Speed Racer Movie ROCKED!!!
    By MykTurk in forum Movies and Entertainment
    Last Post: 05-16-2008, 05:05 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
