Help with Chrysler Maximum Care Coverage??
Results 1 to 8 of 8
    Oct 2015
    Connecticut
    5
    Question Help with Chrysler Maximum Care Coverage??
    I took my wife's 2008 Caliber in for the annual inspection required every 5 years to keep the service contract valid. I asked to check the rear end as we keep hearing a squeaky sound, as in the past at another dealer we were told the sound is coming from the shocks, but they are only seeping and isn't covered, that we have to wait until the shocks are completely worn. Now I've been keeping an eye on them and when I take it to the dealer I mention the squeaking sound, keep being told no change.
    Well now we have moved and took the car into a new dealer and mention the squeaky sound again in the rear, I get a call and told the sound is from the front shocks and they need to be replaced. I was like okay, they're covered under the Maximum Care we have. Get told no because of its normal wear and tear. I call Chrysler to check on the coverage of the Maximum Care and told no the shocks aren't covered, only parts of the shock are covered. This was this past Friday and didn't have the paperwork in front of me. Just going through my records from when we purchased the Caliber, I come across my Maximum Care pamphlet, and it lists shocks are covered.
    Now I know the dealership will most likely tell me no it's not covered as its considered normal wear and tear, should they still cover the shocks regardless if its normal wear and tear. Any guidance is appreciated!
    Jan 2017
    puerto rico
    12
    I just replaced my upper control arms and rear shocks, due to squeaking and just when i got out of the mecanic happy and took the first bump the squeak was there again, so went back to the mecanic for deeper check and the squeak was coming from the rear toe link.
    So i bought them and finally the squeak is gone. Did you check rear toe links?
    Are your tires worn out from inside or outside?
    Oct 2015
    Connecticut
    5
    No, I haven't checked the rear toe links, I will mention that to the dealer. No the tires aren't worn from inside or the outside, what are you thinking with the tires being worn from either in or outside?
  6. #4
    Jan 2017
    puerto rico
    12
    Quote Originally Posted by Calimarine View Post
    Just indications to see if your upper arms and toe links are bad. You could jack the caliber and check for the toes, it may be visible if it's damage.
  7. #5
    Dec 2011
    New York
    4
    I have the same problem with Chrysler refusing to perform warranty work under the Maximum Care program. My transmission needs to be replaced (third time) and they refuse. Dealer was no help, Chrysler 800# no help. They are screwing all Maximum Care purchasers because there is very little you can do. Hiring an attorney will cost more than the value of the repair and there is no guarantee you would win. The only option is to find as many Maximum Care purchasers and band together for a Class Action lawsuit.
  8. #6
    Oct 2015
    Connecticut
    5
    I spoke with the shop foreman and he actually came out and went for a ride with me. I didn't even mention the toe links, he heard the squeaking and suggested the toe links. As the shop was closing for the day, he has the service adviser put a note in the file that when I come back for him to take a look at the car. He also verified that my shocks aren't bad. Only rust he saw was on the shock shields which is normal he said. Without saying it directly I think he realized his mechanic was just trying to get extra money for the shop. Thank you for the tip on the toe links.
  9. #7
    Oct 2015
    Connecticut
    5
    Totally agree with banding together for a Class Action lawsuit. Apparently starting in 2018, Chrysler is being required for all Maximum Care purchasers to show their insurance for the dealer can submit a copy to Chrysler to verify you are the original owner. Chrysler has realized they shot themselves in the foot offering Max Care, so now they are trying to find any way to not cover parts they are supposed to cover.
  10. #8
    Dec 2011
    New York
    4
    The truth is that Chrysler knows you are the original owner. They have VIN data from your registration which they use to contact you if there is a recall. it's just a ruse. Other Chrysler/Dodge forums have similar complaints Maximum Care complaints as well.
  11. Remove Advertisements
  1. 2007 TSB/Dealer Coverage
    By ybshore in forum Dodge Caliber General Discussion
    Last Post: 04-28-2017, 05:55 AM
  2. Mechanic Coverage? 4 years or 48000 miles
    By birdy in forum General Maintenance and Detailing Forum
    Last Post: 03-25-2011, 05:32 PM
  3. Maximum Power/ Torque
    By Race King in forum Custom Dodge Caliber Performance Mods - Engine- R/T (Uptown)
    Last Post: 04-07-2009, 10:40 PM
  4. Maximum Torque Split to Rear Wheels - AWD Caliber
    By hiredgoons in forum Dodge Caliber General Discussion
    Last Post: 04-11-2008, 01:01 PM
  5. Warranty coverage for Ticking sound?
    By zta1917 in forum Dodge Caliber Mechanical Problems and Questions
    Last Post: 08-06-2007, 08:23 AM
