reset codes reader wont read
Results 1 to 5 of 5
    Jan 2018
    Illinois
    3
    Default reset codes reader wont read
    My son has just bought a 2007 caliber 2.0 auto and the gas cap warning is on, i hooked my old centech #94168 scanner up and it wont connect will show error, i hook it to my blazer and it works fine is there some rediculously easy reason for this? am i holding it wrong, facing the wrong direction, too early in the morning?
    Apr 2008
    Lake Wales, FL
    9,658
    34
    Your scanner may not be compatible with a Mopar? IDK. Take it to autozone, o'reilly or advance and see if they'll run codes on it for you. It's free.
    Crazy can be medicated, ignorance can be educated, but you just can't fix stupid.
    Charlie Patterson
    Jan 2018
    Illinois
    3
    was planing on it just wondering if there was something unique about the port, there seems to be lots of little things i am learning about it, next is led lamps install
  6. #4
    Oct 2008
    Delhi, ON, Canada
    589
    10
    Me sure you install resistors inline with the LED's.
    It's possible your wiring may be worn behind the battery tray on the drivers side.
    I had this issue, would read some codes sometimes but wouldn't delete. Solved it by fixing the wiring that was chafed.
  7. #5
    Jan 2018
    Illinois
    3
    thanks, i am hoping that this was a wise purchase for him
  8. Remove Advertisements
  1. OBD2 Code Reader
    By Prop1 in forum Product Reviews
    Last Post: 10-23-2016, 05:43 PM
  2. ETC light keeps coming on Dodge Caliber 2008 2 litre automatic no fault code on reader
    By Gillscott63 in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 07-17-2014, 07:16 AM
  3. [DISCUSSION] Just picked up a PLX Kiwi Bluetooth OBDII Reader...
    By Spz0 in forum Dodge Caliber General Discussion
    Last Post: 02-23-2013, 06:52 PM
  4. Long time reader, finally a member
    By conan563 in forum Newbie Checkin!
    Last Post: 02-28-2010, 05:26 AM
  5. EVIC reset all...
    By Rodentman in forum Dodge Caliber General Discussion
    Last Post: 02-24-2008, 05:16 PM
