2009 caliber sxt start stop problems - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Oct 2008
    Delhi, ON, Canada
    589
    10
    Well you read wrong. The relays are all in a box behind the drivers side headlight.
  3. #12
    Oct 2008
    Delhi, ON, Canada
    589
    10
    Had to deal with this this morning in fact. Worked a 12 hour shift went to leave work and no start again. Pulled the whole front right side apart and what do I find but 2 relays with rotten pins and one rotten female terminal.
    When you pop the top on the relay box there are 4 relays.
    Top right is cooling fans.
    Bottom right starter
    Middle bottom fuel pump
    Left bottom is cooling fans too.
  4. #13
    Jan 2018
    Alberta Canada
    10
    21 10 Amp Red IOD Feed Intrus Mod/Siren (If Equipped)
    doesnt have power at all and found a blue wire going into the relay block messed up.
    Ran out of daylite to continue.
  5. #14
    Oct 2008
    Delhi, ON, Canada
    589
    10
    The 07/08s use a different style relay box with 4 Square relays, 09+ they went to the smaller OMRON rectangle relays. Rockauto/ Napa want $18-30 bucks canadian for chinese made replacements.
    Digikey.ca or .com has the original omron relays for $6 Canadian I ordered 4 new ones.
    You will have to replace a couple pins no doubt if yours has rotted out too.
    Right now I have been driving around with only 2 relays and no cooling fans. But she is cold as hell here anyhow, have never gone over 180* on coolant.
    I ordered 4 relays for $34 shipped. ($8 flat shipping)
    I also removed the relay box from its mount and pulled it up from under the headlight to sit in front of the TIPM box so you can actually access it.
  6. #15
    Jan 2018
    Alberta Canada
    10
    Awsome write up,I switched relays around no change,what I did see is a green wire that is missing some plastic coating and main power wire from battery to Tipm has possibly shorted to ground.
    Everything still works but won't start or turn over still....No fuses burnt.
  7. #16
    Oct 2008
    Delhi, ON, Canada
    589
    10
    I was able to change the two rotten pins on mine, crimped, soldered and sealed. Also covered everything in dielectric grease inside and under the relay box to prevent further issues with corrosion.
    The $5 made in USA relays work perfect.
    Oh and just and FYI I had to change my signal bulbs in the front anyhow so I pulled the whole front bumper cover and it only takes maybe 20 min. (YouTube changing caliber Headlights).
  8. Remove Advertisements
  1. Dodge Caliber 2009 won't start
    By tabishjamal in forum Dodge Caliber Mechanical Problems and Questions
    Last Post: 02-10-2015, 08:17 AM
  2. 2009 Caliber SXT won't start...need help!
    By ebarratt97 in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 05-09-2014, 06:44 PM
  3. 2009 Dodge Caliber sxt won't start, Help Please
    Last Post: 05-07-2014, 07:07 AM
  4. Mopar remote start problems
    By tmx218 in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 09-24-2011, 10:19 AM
  5. Start problems
    By davidwp in forum Dodge Caliber Mechanical Problems and Questions
    Last Post: 04-07-2010, 06:55 PM
