Cigarette lighter has no power
Results 1 to 8 of 8
    Aug 2014
    FL
    21
    Default Cigarette lighter has no power
    I have a 2009 Caliber SXT that I need help diagnosing why the cigarette lighter has no power. Other items such as the a/c outlet in the armrest and the rear windshield wiper works just fine. Only the cigarette lighter does not work.
    Here’s what I’ve done so far…
    - The number 16 and 12 fuses are fine. I visually inspected them as well as with a meter, but just in case I also replaced them with new fuses. Still no power.
    - I replaced the cigarette lighter socket itself with a new one. Still no power.
    At this point what else can I check? Specifically, what are other reasons which would make the outlet not work?
    Thanks again for your help.
    Sep 2008
    London
    11,957
    29
    I would not replace the unit before checking for current at the feed wire and continuity on ground.
    Did you ? Only powered with Ign Key (Acc or On).
    While the power outlet is very similar to a cigar lighter base unit, it does not include the two small spring-clip retainers inside the
    bottom of the receptacle shell that are used to secure the cigar lighter heating element to the insulated contact. It
    has 12 volt battery voltage when the ignition is in the ON or ACC positions.
    If no breaks visible then I would run new ones.
    Aug 2014
    FL
    21
    Quote Originally Posted by Aleks View Post
    Perhaps these are dumb questions, but...
    1) How would I test continuity on ground? What's the procedure?
    2) You say, "If no breaks visible then I would run new ones." Are you saying run all new wires for the cigarette outlet? How would I do that? When I took the console out I could only see about 6 inches of wire before it was wrapped in loom and went under the carpet. Where would I run the wires from?
  6. #4
    Aug 2014
    FL
    21
    I'm just going to test the ground for continuity to test that side. Also going to run a test wire from the battery and the meter to ground to see if that gives me 12v. Hopefully it's just the ground, but worst case I'll use a fuse tap to run a new line to the oulet if the hot side is bad.
    I'll let you know how it goes.
  7. #5
    Oct 2008
    Delhi, ON, Canada
    540
    10
    Why are you worried about the 12v when you have an inverter outlet?
  8. #6
    Aug 2014
    FL
    21
    Because it's my wife's car and she said so :-) I'm pretty sure it's a bad ground but I need to find the time to re-ground the outlet and see if it works.
  9. #7
    Sep 2008
    London
    11,957
    29
    Tap any power supply with tester to see if it grounds on the outlet.
    Run power direct from the battery side of any block into a fuse then through the bulkhead. You can put in your own relay from an Acc supply to be clever.
    replaced - hub bolts, warped rotors, 3 batteries, 2 screens, 12 alloy wheels, seat cover, armrest, Track-rod ends, clutch master cylinder, LH tail unit, LCAs, rear toe link,
  10. #8
    Aug 2014
    FL
    21
    To close this one out for anyone who may have this problem in the future...
    I ran a wire from the negative battery terminal to one lead of a multi meter and touched the other lead to the outlet ground. I had continuity so I knew the outlet ground side was good.
    Then I ran the wire from the positive battery terminal to the feed side of the outlet. Then I put one meter lead to the feed side of the outlet and the other lead to the outlet ground. That gave me 12v.
    So that told me the feed wire was bad somewhere. I just ran a fuse tap off the #16 fuse and ran a new wire to the feed side of the outlet. That gave me 12v back to the outlet and also meant the outlet only worked with the key switched on like normal and not hot all the time. Outlet now works and the mrs can charge her phone. Happy wife, happy life.
    Thanks again for everyone's help!
  11. Remove Advertisements
  1. Cigarette lighter/rear wiper problem
    By dandelion in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 07-22-2017, 05:58 PM
  2. Cigarette lighter
    By fittsy in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 09-16-2013, 08:57 AM
  3. Dashboard light, rear wiper, cigarette lighter & sunroof issues
    By chieffitzy in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 01-18-2013, 06:40 PM
  4. No more electricity in cigarette lighter
    By vaheednzh in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 08-10-2011, 01:21 PM
  5. 12v Cigarette Lighter is not working
    By penet05 in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 03-07-2011, 02:13 PM
