Scan Code P1607
Results 1 to 5 of 5
Thread: Scan Code P1607
    Dec 2012
    Indian Trail,NC
    2
    Default Scan Code P1607
    My horn has not worked for a while and just got it replaced. When I picked up my car from the mechanic the car would not start! He jumped it off and said I should drive it around so the alternator would charge it up. So I get into it this morning and nothing!! I then take it up to Autozone and they tell me the battery is dead. Its the one from the factory and my car is a 2007. Also my engine light came on this AM with code P1607. I had a extra battery and installed it but the car still won't start with out jumping it off! Any suggestions?
    Jun 2006
    Planet Earth
    15,004
    44
    Quote Originally Posted by Geneo View Post
    The PCM isn't getting ignition power. Could be a fuse, connection, or damaged wire. Could also be that the battery cables have corrosion and the PCM is seeing less than 10 volts. If you take a meter and check the battery posts, and then check the voltage on the cable clamps you'll know if that is the case. Could also be the replacement battery has shorted plates under load.
    Brad
    After 9+ years, 99% of all possible questions have been 100% answered. They're here, it just takes some coaxing.
    Retired this day December 31,2014!
    Dec 2012
    Indian Trail,NC
    2
    Thanks Brad checked all you mentioned earlier in the day all checked fine. I'm just mind boggled that prior to taking it in to have the horn replaced everything except the horn worked! At this point I wished I would have not listened to the wife and replaced the horn myself when I had time!!
  6. #4
    Jun 2006
    Planet Earth
    15,004
    44
    Did you actually check the battery while trying to crank the engine? You should also be looking at wires that may have been damaged during the horn replacement. I think the issue was probably caused by the mechanic that replaced the horn. You may have a pinched wire that drawing power, but isn't a dead short.
    Brad
  7. #5
    Apr 2018
    Grovetown, Georgia
    2
    I just have the same problem and got told that I have to replace the computer (ecm). I l ready checked the battery, replace the starter, etc,,,
    Only need to replace the ecm tosee if problem is solved.
  8. Remove Advertisements
  1. Can I reset ODB II code?
    By Steve07RT in forum Dodge Caliber Mechanical Problems and Questions
    Last Post: 08-30-2012, 07:01 PM
  2. P0016 code, and an endless list of possibilities...
    By michac in forum Dodge Caliber Mechanical Problems and Questions
    Last Post: 08-05-2012, 07:38 PM
  3. Long list of future mods...HELP!
    By devlin745 in forum Custom Dodge Caliber Interior Modifications - Audio / Video
    Last Post: 08-15-2009, 12:20 PM
  4. scan qauge II
    By rgb in forum Custom Dodge Caliber Interior Modifications - Audio / Video
    Last Post: 08-13-2007, 01:46 PM
