Battery Selection - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Sep 2008
    London
    11,984
    29
    All petrol Calibers have the same size.
    The diesel has a larger battery but don't know about the trays.
    The Case sizes may be the same but the code reference may be different.
    The Battery Council International (BCI) maintains the standards and specifications for North American battery manufacturers. In Asia, manufacturers conform to the Japanese JIS standard, while Europe adheres to the EN, IKC, Italian CEI, and German DIN specifications.
    replaced - hub bolts, warped rotors, 3 batteries, 2 screens, 12 alloy wheels, seat cover, armrest, Track-rod ends, clutch master cylinder, LH tail unit, LCAs, rear toe link,
  3. #22
    Sep 2008
    London
    11,984
    29
    alpha-batteries.co.uk/brands/optima-batteries
    Just ordered a Red Top for next day at £149
    AGMs almost run to that.
  4. #23
    Sep 2008
    London
    11,984
    29
    4 years later battery time again. ALL DIMENSIONS METRIC MILLIMETERS.
    Optima 4.2 is still around the same price
    Optima has always come with a 2 year warranty whereas other AGMs come with a 4 or 5 year warranty.
    Some listings now show Optima with a 4 year warranty.
    Optima themselves say its a 3 year warranty plus an extra year if purchased direct with their charger.
    I barely used mine for two years because the fault turned out to be wiring loom and I reinstalled the Mopar.
    The recommended battery for the Caliber CRD is Optima Red Top RT S 4.2 (model 8002-250, part 802 250 0008882)
    50 Ah 815 CCA dimensions 256l x 174w x 200h
    The MOPAR version is MPS24 0509 3074 AA 48 Ah 800 CCA
    The petrol Caliber recommends Optima Red Top RT s 3.7 (model 8020-255) 44 Ah 730 CCA 237l x 171w x 197h
    The battery tray fitted to the Caliber CRD is Mopar 05115730AA. If you lift out the battery you will see the part number and manufacturing date embossed in the base. It might be the same one for petrol models.
    Taking this tray out (5 bolts) for accurate measurement the base accommodates 252 lengthways and the width grip hold downs will take 170-180w. The advice from battery suppliers is always measure your existing battery and not follow their 'suggested' fitments.
    The height from the fitted tray base to the front frame is 230, however the diesel air intake curves down reducing the height to 205 at the rear.
    The height is the battery case, the terminals are either side of the intake so can be higher like on the Optima.
    The Optima terminals are central with the wiring routed from the rear. The recommended alternates with +ve on the left have terminals at the front. It would seem just as reasonable to connect the terminals at the rear for the wiring loom.
    There is a wider selection with +ve on the right, just fitted reversed so the label is upside down.
    For petrol Calibers the suggested alternate is 005R 230l x 170w x 225h 60Ah 540 CCA
    reversing a 005L boosts this to 65 Ah 580CCA.
    Note the additional height compared to OPTIMA.
    Back to Diesel. The suggested fitments by Car Parts suppliers are all different lengths
    Tayna 096R is 278l
    EuroCarParts 017 is 353l
    GSF 086 is 278l
    Exide Spiral EP450 is 260l x 172w x 205h 50Ah 750CCA
    If you have fitted any battery other than Optima please post your experience of fit and performance.
    Considering modifying the tray (for length) cutting off the electronics mount would seem the only option. There is not much room, the box would need remounting or zip tie.
    For diesel within the tray constraints 252lx180wx205h the largest battery box I could find is 027 242l x 175w x 190h.
    Of the 027 batteries the best performance using rear terminals is Exide Premium (Calcium) 4yr warranty 64 Ah 640 CCA EA640 027TE. The supplier said they could not give the warranty if used in the Caliber as it's not the recommended application. Other AGM 027s are available (Exide/Bosch/Varta) for twice the price that give 680CCA so could work but again questions about the warranty.
    The specified Optima costs a third more. I'd better get my 4 years from it !
  5. #24
    Sep 2008
    London
    11,984
    29
    For those who like to research these threads before going to the vehicle and want to know which tools to take there's this:
    Battery leads are tightened on with 8mm nuts.
    The battery hold down is a 14mm bolt at the base which needs a 12" extension.
    If taking out the tray for any reason it is 5 x 13mm bolts and nut.
  6. Remove Advertisements
  1. Caliber Battery Drain Mystery Solved?
    By synesthesia in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 04-24-2011, 08:34 PM
  2. New Battery DEAD after 12 day vacation
    Last Post: 04-18-2011, 01:18 PM
  3. Battery issues
    By jmfolds in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 09-27-2010, 03:43 PM
  4. Battery Problem
    By TrueBlue in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 03-12-2010, 05:01 PM
  5. Battery Issue
    By fugies in forum Dodge Caliber Electrical Problems and Questions
    Last Post: 05-17-2009, 05:05 AM
Tags for this Thread
