Brendy had a water leak that required removal of the front left fender to seal. He describes the fix in this post:
Well this time last year I had the dam issue, front driver side(right Euro) and the two rear foot wells wear soaking wet, filled about half an inch above carpet level, a year later i haven't had a single problem since it was fixed under warranty, i was told my problem was from the front fender/wing area under the hood next to the hood hinge, this is where 3 parts of the car body join/meet and this is where water was ingressing over time and traveling to the rear foot wells.. so it was fixed.. if you are still getting fogged window screen i might say you still have a leak or the carpet is still damp, ask them to check the area i have pointed out to you..
i also demanded a new carpet for the same reason and promptly got one..
in this pic, the top arrow is where i was told was the area where water was entering..
